Moderators: Henry , Mods
alexm
Posts: 9 Joined: Mon Nov 18, 2002 3:46 pm
Post
by alexm » Tue Nov 19, 2002 3:50 am
Could someone please help?
I just bought the VFD yesterday, i followed the instructions exactly.
I am using LCDC.
When i use the option test display it is fine, it displays the text fine.
But when i do anything inside the program like just scrolling text i see full blocks go across the screen every other second?!
can anyone help please?
cheers
Cheese
Bit-Tech.net
Posts: 337 Joined: Thu Dec 06, 2001 4:00 pm
Post
by Cheese » Tue Nov 19, 2002 7:19 am
In LCDC setup have you selected the definition file for the vk204? Also make sure the com speed in LCDC is set to 19200...
Rob.
p.s. what OS are you using? Have you tried programs other than lcdc? See the 'cool uses' section on
www.matrixorbital.com
alexm
Post
by alexm » Tue Nov 19, 2002 8:04 am
i have changed the port speed to 19200 in both the program and the com port settings.
I have also made sure i have the correct defination file open .
I am using windows XP.
Ok, i will go and try some other programs.
alexm
Post
by alexm » Tue Nov 19, 2002 8:37 am
ok i have downloaded some other programs and when i send some txt to it it seems to be fine.
but still when i send txt to it from LCDC it send blocks over it.
Mat-Moo
Posts: 502 Joined: Wed Jan 16, 2002 4:00 pm
Post
by Mat-Moo » Tue Nov 19, 2002 11:02 am
Does the virtual screen show correctly? Can you get a screenshot...
alexm
Post
by alexm » Tue Nov 19, 2002 12:03 pm
The virtual screen is ok.
When i press start on LCDC it goes funny, soon as i press stop it goes ok.
I have tried to catch the screen here.
thos blocks appear randonmly and go from right to left
Cheese
Bit-Tech.net
Post
by Cheese » Tue Nov 19, 2002 12:15 pm
Chuffin weird, what OS are you using?
Rob.
Mat-Moo
Post
by Mat-Moo » Tue Nov 19, 2002 12:30 pm
I guess you have a test screen on there - what is in each line?
alexm
Post
by alexm » Tue Nov 19, 2002 12:33 pm
i am using windows XP Pro Build 2600
The only thing that was in the line is the text. I made sure nothing else was loaded.
I will try another PC.
Mat-Moo
Post
by Mat-Moo » Tue Nov 19, 2002 3:23 pm
Weird - have you got another com port you can try? Possibly even another cable? I'm not sure what else to suggest I'm afriad. What about other apps? LCDSmartie for example? Does that work?
Posts: 3014 Joined: Tue Aug 14, 2001 6:00 pm
Post
by Henry » Wed Nov 20, 2002 1:44 am
Do you have the blinkng cursor turned off?
alexm
Post
by alexm » Wed Nov 20, 2002 9:36 am
i havent turned off the blinking sursor.
should i?
Post
by Henry » Wed Nov 20, 2002 9:45 am
Yes.
alexm
Post
by alexm » Wed Nov 20, 2002 9:52 am
sorry, i have just turned the blinking sursor off and now it works fine.
thanks for your help!!
Post
by Henry » Wed Nov 20, 2002 9:54 am
NP, don't forget about posting in the gallery...
Enjoy.
