D-Tek Inline Temp Probe
Marquis
Post by Marquis »
Is it possible to connect a D-Tek Inline Temp Probe to a MX 212? :-?
The D-Tek Inline Temp Probe only has 2 cables and the MX 212 has 3 pins...... :grr:
http://www.dtekcustoms.com/browseproduc ... Probe.HTML
Any help would be appreciated! <:)
Hello Marquis,
Thanks for your post.
The temp probes supported by the MX series are Dallas 1-Wire devices. These come with 3 connections, +5V, Data and Gnd. If D-Tek's Inline Temp Probe is a Dallas 1-Wire device, then the MX series can support it.
I checked the link you gave but did not see that there are two wires to the Inline Temp Probe. Do you have some kind of data sheet?
That's pretty nice. We will incorporate support for it in the GX series in the future.
Marquis
Post by Marquis »
Thanks for your help guys, here's a photo of the inline probe... :D
As you can see it's only got 2 cables, it uses a standard 10k ohm thermistor -50 - 110 Deg C (320.2 - .7579 kohms).
Could not find any other details, will e-mail them for more info :eyebrow:
thanatos2k
Post by thanatos2k »
I recall you can short two of the three legs on those dallas temp sensors, but the one you referenced uses a standard thermistor, not a 1-wire bus. :(
bwhiten
Post by bwhiten »
A "1-Wire" device is digital. This sensor, since it uses a thermistor and is only two wires, is analog. Basically one wire on each end of a resistor that changes value with changes in temperature. You would need to set up a current source through this device then feed the resulting voltage drop to a D/A converter for measurement.
