Using buttons instead of a keyboard?
LiqTenExp
Post by LiqTenExp »
I am new to LCD's being used with computers to display data. If i had a program like LCDC and wanted to be able to use back forward stop and play, and a power button (5 buttons total) near the display to control it instead of a keypad. I was wondering if that is possible. I was looking to get a 20x4 MO backlit LCD display.
Yes, as long as the button shorts out two lines it's all good.
LiqTenExp
Post by LiqTenExp »
What do you mean by shorting out two lines? Two connections on the keypad connection? For example the 20x4 LCD from MO?
Whoosh
Post by Whoosh »
Hi there,
Check the manual for the display. It's pretty well documented. The keypad connector is setup as a matrix with rows and columns.
So, what you want to do is connect a row and a column pin with a momentary-style button which connects the 2 when it's pressed.
Cheers, Whoosh
Atarien
JackyPC
JackyPC
Post by Atarien »
this what i did in my project :
http://www.jackypc.com/articles/146/global.jpg
the online documenation has been very useful
babber
Post by babber »
I have made an external remote which uses 8 switches. I have a simple diagram that explain how to connect switches in rows and columns. See http://mysite.freeserve.com/winamp_remote/switch.htm
Cheers
Babber
ijoat
Post by ijoat »
babber: THANK YOU so much for the link to your website explaining the button wire diagram. I'm new to LCDs and have been racking my brain trying to understand the buttons actually work. I've seen several desciptions and diagrams but none of them made sense until I looked at yours. I feel like a "born again". :-)
Thanks dude!
