Fan control and hmonitor
Osm3um
Post by Osm3um »
I am trying to control some fans connected to my mx610 using data from hmonitor. I can sucessfully make it so that change speeds on startup/shutdown events, however:
I can not seem to make it changed based on a temperature. Somethign like "If CPU temp >= X then change fan speed to Y".
I did notice that their are some more advanced options available using speedfan/MBM5, but is there any way to do this with HMonitor?
The probelm I have with MBM5 is it appears to be a dead end as there is no more development occurring. the problem I haev with Speedfan is it takes so long to start....
Bob
Robert T Williamson
Osm3um
Post by Osm3um »
Sorry, thought I woudl mention I am doin this:
Event: Sys->On condition
When it is Yes: [#$HSMTemVal002]>=80 (I have chnaged this to different things, so don;t look at the specifics, but rather, is the technique correct?)
Action GPO->Advanced->Increase PWM
Bob
Robert T Williamson
dtorner
Post by dtorner »
the technique you used should be ok, maybe LCDC is driving the fans for itself.. check in the "Advanced MXx features\GPO/PWM control"dialog of LCDC configure/test, if the GPO advanced control is set to "manual, set in screen builder", you could also test to use "auto, temperature based" to allow LCDC to be your automatic digital baybus :)
