Need help to connect Internal USB.
jhego
Post by jhego »
I have an A8v motherboard. Attached is the manual for the USB header. It shows you the type of connection i have. Where do i connect the colors?
Alienware Aurora
AMD FX-53 Socket 939 | 1GB Corsair Extreme DDR | Nvidia 6800 Ultra | SoundBlaster Audigy 2 ZS | AlienIce-Astral Blue | 160GB Seagate Barracuda 7,200 | 16X DVD | 52x32x52x CD/RW | ViewSonic A75F CRT | Logitech MX510 | Logitech Z-5300
If you are using the internal USB cable for our display the following connections should be made.
+5V(red) d-(white) d+(green) ground(black)
USB+5 USB_P8- USB_P8+ GND.
The following link is a guide to installing the internal USB cable.
http://www.lcdforums.com/forums/viewtopic.php?t=1290.
You can plug it into USB56 or USB78
