got the diplay hooked up and nothing happens
extreme76
Post by extreme76 »
bought the glk12232-25wbl hooked it up and power on got the startup screen fine but cant seem to get any programs to work i installed lcd driver is this why after doing a bit of reading i see that may have been a mistake any help from henry or people with the same model what did u do from out of the box state and on thanx
specialk
Post by specialk »
First of all, try mogd.exe (available in the downloads section of http://www.matrix-orbital.com) and see if you can communicate with it. If you can display text, draw pictures, etc., please tell us! I'm actually working on programs specific to the graphic LCD, so any new and unique programs I happen to put together will be posted here :smile:
-special [k]
extreme76
Post by extreme76 »
actually i cant do anything with it it looks like it is trying to comminuacate the light dims and then brightens but nothen happens ver odd trying it on second pc in am see if same results
Mat-Moo
Post by Mat-Moo »
If you got a rs232 interface plate with black/orange/green wires on it check the order is Green Organe Black as mine was wrong - but thankfully Cheeseman pointed it out :smile: and I had it all working minutes later...
Cheese
Bit-Tech.net
Bit-Tech.net
Post by Cheese »
Yep... and the display dimming sounds exactly like the symptom of having the green and orange wires being the wrong way round in the 4BR cable. Careful though, if they are the wrong way round pop them out (by poking the copper contact at the side of each hole and pulling and then swap them round. Do nt be tempted to put the 4BR cable in the wrong way round (as this will earth the 5V line).
r.
extreme76
Post by extreme76 »
thanx guys that does seem to be whats wrong it was sent being black green orange
extreme76
Post by extreme76 »
one more question what are the screen size settings seeing it dosent seem to have my screen size should i just use 4x40
Cheese
Bit-Tech.net
Bit-Tech.net
Post by Cheese »
What's the screen size of your glk12232-25-wbl?
Umm 122x32 silly :razz:
Witht he normal small font and the font metric set correctly this correspons to 20x4 characters.
r.
