I set it all up and it works fine except one problem that is agravating as heck.
When I boot the computer and LCDC starts automagically lines 2 and 3 on the display are swapped.
If I stop the display and restart it in LCDC they are fine.
I've seen a couple similar posts (here or on LCDC's forums), but a solution was never presented publicly.
What's the deal? Is there a set of events I can use, or a line of commands I can send, to stop and restart the display via a keypad press or with the Sys-On Start event?
I have the right screen def file as best as I can tell
I've posted this on LCDC's forums as well as I'm not sure if it's a LCDC or hardware problem.
Also if I use Bootedit I seem to be able to only change the first two lines of the display's boot screen, this isn't a big deal, but a fix/suggestion for that would be cool too
Thanksin advance.
