Lines 2 and 3 on the display are swapped?!
techie
Post by techie »
OK so I have a MO VK-204-25 (wide voltage, serial VFD).
I set it all up and it works fine except one problem that is agravating as heck.
When I boot the computer and LCDC starts automagically lines 2 and 3 on the display are swapped.
If I stop the display and restart it in LCDC they are fine.
I've seen a couple similar posts (here or on LCDC's forums), but a solution was never presented publicly.
What's the deal? Is there a set of events I can use, or a line of commands I can send, to stop and restart the display via a keypad press or with the Sys-On Start event?
I have the right screen def file as best as I can tell :)
I've posted this on LCDC's forums as well as I'm not sure if it's a LCDC or hardware problem.
Also if I use Bootedit I seem to be able to only change the first two lines of the display's boot screen, this isn't a big deal, but a fix/suggestion for that would be cool too :)
Thanksin advance.
Cheers!
techie007
This isn't an MX series, so it does require you to me a little more in touch with the display now... RTFM ;)
Anyways, this display works line 1,3,2,4 by default, turn on AutoLineWrapOn and you should be good to go.
techie
Post by techie »
Henry wrote:This isn't an MX series, so it does require you to me a little more in touch with the display now... RTFM ;)
I read something about that AutoWrap along the way, but I think I had been led to believe it should be OFF. But hey, I don't even think I managed to find it. I'll have to dig a little harder. And where is it in TFM? ;)
And I don't think you want me touching you Henry ;)
Thanks I'll give it a shot and see what happens..
Cheers!
techie007
techie
W00p!
Post by techie »
OK all is good. I set up a AutoLineWrapOn event through LCDC. Put one in for On Start and one in for Resume From Hibernation. Works like a charm now.
My Opus 90W DC->DC power supply comes today and hopefully I can start wiring this thing into the car this weekend (it only took a year ;) ).
Thanks again Henry.
Cheers!
techie007
