Temperature Sensors
Escape
Temperature Sensors
Post by Escape »
Hi Henry:
Are their any plans to make a LCD readout that can read temperatures from sensors that you can place on hardware inside your PC. I would still like it to be able to display info from the serial port but be able to give me temperature readings from my own sensors. The sensors would be Dallas Semiconductor DS18b20 or DS1822 barrel type (3 wire)that can be place mostly anywhere in a PC. I think you can wire up to 32 sensors on one line to read temps. I am not talking about reading temps from the onboard motherboard sensors via the serial port and MBM software. The onboard sensors are not accutrate at all an I would never rely on those for temp reading. I want something that is hardwired to the actual component of my choice and is independent from the computer as far as temp readings go.
A competitor has such a device (633) but it only comes in the green display which I do not like.
I want a LCD display that I can choose the color display, be able to display computer info (via serial connection) and to take my own temperature readings with hardwired sensors. All this in a in a 5.25 bay with faceplate.
Escape
Post by Escape »
I forgot to include my rig and some pictures in my first post
I think it would look real cool with a LCD display
MY RIG:
AMD Athlon XP 2600 (333 fsb)
MSI KT4 Ultra
XP Professional SP-1
512 Corsair PC3500 XMS
3 Western Digital HD (2) 100Gb and (1) 30Gb
Enermax EG465AX-VE powersupply
MSI Gforce4 ti4600 128mb
Audigy 2 sound card
Promise Ultra 133 TX2 card
Intel Pro/1000 MT desktop adapter
Plextor 40x12x40 CDRW
Toshiba DVD
Coolermaster ATC-110 case
CoolerMaster HHC-001 Heatpipe HS
http://home.nyc.rr.com/escape068/Computer%20Photos.htm
