Can't connect @ 19200
HamIAm
Post by HamIAm »
Hi Folks. Just got my vk204-25, and I can't seem to connect to it @ 19200. I've discovered I can connect at 9600, but can't get the spectrum anilyzer to work in winamp. I'm using win2kP with an asus a7n8x athlon 2600+. I'm using com2 since it's inside the MB (using the header on the MB).
I did find under device manager that the com2 was set to 9600, so I turned it up to 19200 and now I don't get anything.
I'm trying to use this plugin: http://www.markuszehnder.ch/projects/lc ... index.html
Any idea's?
Bursar
Post by Bursar »
Are there jumpers on the LCD that need to be moved in order to change the connection speed?
HamIAm
Post by HamIAm »
Bursar wrote:Are there jumpers on the LCD that need to be moved in order to change the connection speed?
Yep, that was it. Now if I can just figure out this dang plugin.. :)
I was hoping LCDC would do the equilizer.. I'm just glad it's working now.
Thanks Bursar! You Da Man!
Mat-Moo
Post by Mat-Moo »
LCDC does do a winamp equalizer :)
HamIAm
Post by HamIAm »
mat-d-rat wrote:LCDC does do a winamp equalizer :)
Yeah, it does, but you can only use one visualization plugin at a time.. and I want to use the milkdrop vis plugin.. Unless you can do 2 vis plugins.. I didn't think so though.
