Please Help;
First how do you get the Smartie software to activate upon Startup in WinXP.
When I tried to drag the icon into the start menu the Smartie program begins but the parallell pot driver comes up with an error on the screen (repeated error boxes).
Is there a "Dummy" book to program these VFD diplays, any help would be appreciated....
ok. you should first set the type of LCD you want
if you have a MO VFD you should click on MO, and select a port and port speed (standard is 19200) then you can get it working
to show smartie @ startup drag it into a startup folder in your startmenu-->programs
and then add the -hide option to the link. so it becomes
