EVE Asset Builder (EAB) 2.12.0
Release Notes Version 2.12.0
Link:
https://www.matrixorbital.com/index.php ... t&did=1834
Feature Updates
Font Converter
• Escape Line Break and Reserve Space will be hidden in UTF-8 code point mode.
• Legacy Format: Set bitmap format default to L4.
• Extended Format: Set bitmap format default to "ASTC" and "auto".
• Input Character: Keep it if possible in case the "Input Font" changes.
• Reserve Space: Selected by default.
• Correct hint for Address in Legacy and no hint for Code Point Mode.
• Add code point modes ASCII and Ordinal for Legacy format.
Flash Utilities
• Add "Blob Release" Tab in flash utilities
• Edit the sample code in the Update and Install Blob tabs.
Image Converter
• Add default ASTC options.
General
• Speed up the conversion process of the Video and Animation converter.
• Remember the last folder that users select and use it as the default folder for the
next time.
• Add a summary result for the PNG/JPEG validator.
• Show an error message when the user selects an invalid image.
• Improve the session management.
Resolved Issues
Animation Converter
• Fix the issue of displaying the wrong frame in the case of RAM_G and "No Tile"
mode.
Image Converter
• Fixed the issue where DXT1 L2 was double the size.
Flash Image Generator
• Correct type of xfont asset
