The schematics of "EVE4x-40G-IPS" are required.
pawow2000
Post by pawow2000 »
No matter where I look, I can't find Schematics.
Can anyone please share the schematic for this product?
Product description is too poor.
There is also no information about the standard 20-pin.
I am very confused as to where to look.
The product I purchased "EVE4x-40G-IPS" has neither a USB connector nor a power connector.
Perhaps the company's purchasing manager dropped all options.
Fortunately, there are header pins called 20PIN standard connectors.
Details are required for standard 20 pins.
And is 5.0v not enough for the backlight?
Should I input 12.0V?
Why is there no relevant information in this manual?
Re: The schematics of "EVE4x-40G-IPS" are required.
I wonder if you have a serial number on your EVE4x-40G-IPS you can share so I can check the model?
If you have a VS model you can power it with 5-15V, otherwise it will take 3.3V only.
For now if you please check out this manual for the 20 pin FFC pin out.
