VFD-2041v Problems HELP Please :-)
I can't get any software to work. I have tested it using Hyper Terminal & it works. When I boot up I get flasing cursor.
But when I try LCDC or LCD Smartie 5.0, I get garbage on the screen or it goes blank. Then I have to reboot to get VFD back on? I have tried on com 1 & 2 same thing on both.
I have tested power cable, it is getting 12v. Don't know what else to do.
Help
<font size=-1>[ This Message was edited by: DonG1967 on 2002-07-30 22:02 ]</font>
Help
Ok if you mean in software "LCDC" its set to 19200 in config table. Hardware are you talking about using control panel, then system, & device manager. Open com1 then set speed under port settings? If so, I did change that to 19200. Other setting I did'nt change. I did that after LCDC was installed.
In LCDC, under Definition file the only output I can get is using LCD4041?
When running WinAmp its sending info to the VFD but its very fast and you can't make anything out.
A side note, I've been building computers for friends and family for the past four years. But this is all new to me, saw VFD on The Screen Savers and thought it was very cool.
Don
<font size=-1>[ This Message was edited by: DonG1967 on 2002-07-30 12:24 ]</font>
Don
Sounds like the baud rate ont he screen is wrong... or you have the wrong cable on it.
1) Make sure the cable is a null modem cable (not a standard rs232 cross over)
2) Check that the module has a jumper on j1/j2 to set speed at 19200, if not either change it to so or find out in the manual what speed it is set to (possible 9600?) and try the software again
3) Pray
3) Pray
Ok, here we go. All cables are good. When I try to run the Alpha Demo I get "Unable to open com port:5" then you click "ok", then I get
"Exception EAccessViolation in Module MatrixDemo.exe at 00002d38, Access violation at adress 00402D38 in moduale Matrixdemo.exe Read of adress 505C3A3F"
So I changed to to com port:5 to see if it would read, no luck. Any ideas?
I'm starting to think I have a lemon display.
Thanks for the help. Next tip if any?
Don
Don
Ok, tried MOGD. I can turn display on & off using backlight. But same story for everything else, nothing but mixed up alphabit soup on the screen. No matter what I type.
Also I got to thinking about what Mat-d-rat
said on his post. Make sure cable is null modem and not standard rs232. The cable that came from MO is a stanard rs232. I used my mulitmeter and pins 1 thur 9 match.
If it is a null modem cable should'nt two of the pins be crossed?
yes or no
Remember I got the PC kit from MO. So did they send the wrong cable or not?
Don
<font size=-1>[ This Message was edited by: DonG1967 on 2002-07-31 16:51 ]</font>
yes or no
Don
Can you contact me at myero@matrixorbital.com This way if it is a RMA situation we can discuss the options in greater detail.
If you can turn the backlight on/off the cable must be ok as commands are being sent.
I also just realizes that you have a 204 (20charactersx4line) yet you are using a 404 (40charachtersx4lines) definition. Try chaning the defintition in LCDC to LK204-25 (close enough to see if we can get it working correctly!)
