GTT25 Command listing
ldcaseIII
Post by ldcaseIII »
Is there somewhere a complete listing of the GTT25 Commands and responses. The documentation appears incomplete! I have the GTT protocol and developers PDFs, but there still seems to be quite a lot missing. Specifically today im trying to set the text size of a "DYNAMIC" label at runtime.
Re: GTT25 Command listing
Hello ldcaseIII,
Your are right, we do not have a complete listing of GTT25 command responses. We only chose to document the most important ones.
You may please check our client library from here: https://github.com/MatrixOrbital/Matrix ... entLibrary
You will see how the replies/responses are handled.
If you are to check the library you will see that for updating a dynamic label is basically calling this function:
gtt25_baseobject_set_property_text()
You should be able to find in the library as well how this command is sent and takes care of the responses.
Hope this helps.
