VFD2041 won't communicate
mickc
Post by mickc »
I have a VFD2041 that has been in storage for a little while, and now i cant get it to communicate with any PC.
Using Uproject it will open to comm port but no data will flow.
I have tested the serial port and i works fine, I have 5v at the board.
I have tried using the manual override jumper also.
This unit has been previously modified, the logic board has been separated from the VFD display, and the VFD had been replaced by a larger CU-20049-UW model.
The unit worked fine in this configuration before being put into storage.
Any clues on where to go from here for further testing?
Tino
Re: VFD2041 won't communicate
Post by Tino »
Hi mickc,
Are you able to read from the display? (i.e Read Module or Read Version)
Try This:
1. Perform a Manual Override, do no remove jumper after you power the display on.
2. In uProject select the "Uploader" tab.
3. Select 'Other' -> 'Raw Data'
4. Using Raw data send the "Read Module Type" Command. (254 55)
If the communication to the Board is working you will receive a response.
This will help determine if you are able to communicate to the interface board or not.
Let me know what the outcome is.
Thank you for posting to our forums.
Regards
Martino
Martino DeLeon
mickc
Post by mickc »
Thanks Martino,
I gave it a try, no luck.
I get no response from the board at all.
I even put an RS232 analyser in line with the board and there is no data activity on the RX side.
I am assuming the board is dead. :(
I have just ordered an S-Series X-Board to replace it.
Thanks anyway for your help
Tino
Post by Tino »
Hi Mickc
You are welcome.
Thank you for posting on our forums.
Regards
Martino
Martino DeLeon
