GLT240128 Initialize Label not working
xicJeff
Post by xicJeff »
I am able to write data and perform other functions (clear screen, load a bitmap), but the Initialize Label command isn't working.
I tried sending the following:
TxBuffer[0] = 254;
TxBuffer[1] = 45;
TxBuffer[2] = 2; /* ID */
TxBuffer[3] = 122; /* X1 */
TxBuffer[4] = 40; /* Y1 */
TxBuffer[5] = 180; /* X2 */
TxBuffer[6] = 60; /* Y2 */
TxBuffer[7] = 0; /* Vert */
TxBuffer[8] = 2; /* Hor */
TxBuffer[9] = 4; /* Font */
TxBuffer[10] = 0; /* Background */
TxBuffer[11] = 0; /* CharSpace */
The screen displays "z(<", which is the ASCII for bytes 3, 4, and 6. I'm pretty sure it's supposed to stay blank.
Then, I tried calling Update Label 2 with some text, but the text was written after "z(<", instead of starting at 122, 40.
Do I need to send some other commands before this? I tried with no commands before and with the Clear Screen command before. Same result.
Jeff
Tino
Re: GLT240128 Initialize Label not working
Post by Tino »
Hi Jeff,
What PCB Rev are is your GLT240128?
Also could you check the firmware of your GLT240128 by sending the "Get Version Number" command (254 54) or selecting AutoDetect with Mogd#, the firmware number should be at least v8.3 in order for the Labels to work properly.
Thank you
Martino
Martino DeLeon
xicJeff
Post by xicJeff »
Hi Martino,
I checked the version number and it was 8.2. I did a firmware upgrade to 8.3 and it's working now.
Jeff
Tino
Post by Tino »
Hey Jeff,
That's great! Glad to help.
If you have any other questions or concerns please do not hesitate to ask.
Thank you for posting.
Martino
Martino DeLeon
