LCDProc
zorrua
LCDProc
Post by zorrua »
Hello, I have a GLK19264-7T-1U-USB device and I want to get it working with LCDproc in Linux PC.
Is it possible? How could I show some info there?
zorrua
Re: LCDProc
Post by zorrua »
Hello again,
Is there someone that could help?
Which software do I need to send some info to the device?
Regards.
Tino
Re: LCDProc
Post by Tino »
Hi Zorrua,
The GLK19264-7T-1U-USB can work with Linux. If you haven't installed the drivers for the display you will need to.
Here is a link for an application note for using our displays with Linux:
http://www.matrixorbital.ca/appnotes/Li ... 0Linux.pdf
The App Note gives some detail into having the display recognized in Linux and instructions to install the drivers.
Thank you
Martino
Martino DeLeon
zorrua
Re: LCDProc
Post by zorrua »
Thanks Tino!
I create the “hello world” application and it works, that great.
I want to use it with LCDproc to show some hardware info of my Linux server.
I didn't find any example how to do it with this device, could you help with this?
Thanks and best regards.
Tino
Re: LCDProc
Post by Tino »
Hey Zorrua,
Unfortunately we do not have an example with LCDproc.
LCDproc does have a User Guide on their website here:
http://lcdproc.org/hardware.php3
User Guide:
http://lcdproc.sourceforge.net/docs/cur ... #glk-howto
Hope that helps,
Martino
Martino DeLeon
zorrua
Re: LCDProc
Post by zorrua »
Thanks again!
I use the "MtxOrb" driver and it display lots of info in the screen.
Last question: when I plug the device in the PC, it show and image, I think that it was uploaded by the boy how sell me the device. how could delete this image? or upload an other one?
Tino
Re: LCDProc
Post by Tino »
Hey Zorrua,
If you upload a image that you would like to be in the start up upload it with the ID of '0'.
This will overwrite the image that is there now.
Regards
Martino
Martino DeLeon
zorrua
Re: LCDProc
Post by zorrua »
Thanks again,
How could I upload the image? Need I any especial software?
I don't understand the ID 0.
Regards.
Tino
Re: LCDProc
Post by Tino »
Depending on the PCB revision you have the you can find the manual of your display here:
PCB Rev 2.0
http://www.matrixorbital.ca/manuals/GLK ... 2.0%29.pdf
or
PCB Rev 1.0 to 1.1
http://www.matrixorbital.ca/manuals/GLK ... -7T-1U.pdf
You can find the "Upload a Bitmap File" command in the manual. Also the protocol used to upload an image.
When I say the "ID" this is the Reference ID number that is given to the image when uploading the image. The details to uploading a image can be find in the manual.
Thank you
Martino
Martino DeLeon
