servo control?
jleach
Post by jleach »
Can a GPO be used to control a servo? This link shows how a servo is controlled.
http://www.epanorama.net/documents/motor/rcservos.html
It says that 1.5ms pulses set the servo to one end, and 2.0ms pulses set it to the other. Can a the GPO's be told to turn on/off that quickly/precisely to control the servo? Or would it be better to build a control circuit?
The fastest you could get a GPO to turn on and off is about 40mS... so not fast enough to do this, sorry...
jleach
Post by jleach »
No problem. I'm working on bribing an EE friend of mine to design the circuit I need. I need to be able to adjust the speed at which it moves, and the endpoints, so it's a bit more complex than I originally thought.
It is going to be controled off off a GPO, tho.
James
James
I hope you post some schematics, pictures and a how to, I'm sure others would love to see this, I will host if if you need :smile:
