Wall wart power source
harriscohen
Post by harriscohen »
I am writing to inquire if I can connect a 12V wall wart directly to a 4-pin SIP adapter (pins 1 & 4 only) in order to power my LK162-12-V. I am using the LCD in an embedded environment and a regular floppy drive cable is not useful and my RS-232 ports do not send power down pin 9.
Thank you. Harris
Thank you. Harris
I don't see why that wouldn't work. As long as you connect it properly it should work. The power regulator on the LCD will keep it safe.
