brushed aluminium pc mouting bracket for MO lcd - and invers
psykik
Post by psykik »
Is there a brushed aluminium mounting bracket for either the pc baybus or the newer bloo lcds?
Ps when will we see an inverse bloo lcd larger than 20 x 2?
No brushed aluminum, the bracket is metal... I would say use use the blanks you have, trip them down, cut out the LCD window and then glue them to the bracket...
And yes, the inverse blue will be coming in 5-6 weeks in the 4x20 size.
Cheese
Bit-Tech.net
Bit-Tech.net
Post by Cheese »
You should do aluminium face plates henry... I'm sure you'd sell 100's of them, enough to justify their cost to you even though you might not sell as many as you do the black/white :smile:
r.
Thinking about it... I'll pitch the idea by in the next meeting and see what happens...
gordy_hand
Post by gordy_hand »
r.
I would recon you would sell more than the black and white ones as more modders have got alu cases as the prices come down and down :smile:
Gordy_Hand
Luvien
Post by Luvien »
bump!
I want to buy a LCD too and i'm looking for an Alu look to match my lian li.
It would be very nice if you can make these bays.
Cheese
Bit-Tech.net
Bit-Tech.net
Post by Cheese »
buuuut mo sell more of these things to other markets you know :smile:
r.
Thlayli
Post by Thlayli »
Until then we have the wondrous dremel tool. It really isn't too bad to modify an aluminum bay insert, I was scared but mine turned out pretty sweet. All you want to do is mark out where the screen is going to fit (I recommend making the hole just large enough for the actual lcd screen and not the plastic edge around it) and cut a hole a few mm smaller than it. Then get out a file and take out burrs and imperfections in the cutting with the file and watch some TV while doing it. After about 3 episodes of the Simpsons, you should be set. I'll get a pic on here if I can steal^H^H^H^H^Hliberate my brother's digital camera.
P.S.-> Make sure after marking it out that you put some heavy duty tape on the parts that you don't want to cut, like duct tape or something. Cutting a soft metal like aluminum by accident with a dremel is quite easy, and the tape will help prevent that quite a bit.
<font size=-1>[ This Message was edited by: Thlayli on 2002-06-26 15:18 ]</font>
