NK204
anaknangputa
Post by anaknangputa »
I need some help...
I just recv'd my NK204 [w/ wide voltage option] from MO. After reading and following the instructions for installation [and I went over several times] The only thing I get on the panel is a blinking cursor and nothing else. The unit is on COM1, 19200 baud, 12v plug. I just want to be able to enjoy this thing.
Please respond, anyone..
WhyPush
Post by WhyPush »
Without much detail, I'll ask a few questions:
Have you installed and set up any software to run the LCD? Have you tried Com2 just to make sure? HAve you checked both the module and the software setting baud rates to make sure they match?
BTW, I had similar issues when I forst installed... :wink:
_________________
---------------<br>
WhyPush<br>
WhyPush.com
<font size=-1>[ This Message was edited by: WhyPush on 2002-05-02 07:24 ]</font>
What he said... the blinking cursor is a good thing, meaning the LCD is up and running with no problems.
anaknangputa
Thanks for the reply.....
Yes I did try COM2. I made sure all the connections [power and data] were correct. My NK204 has the wide volt. option and I thought I may have incorrectly switched the cables, but the blinking cursor is a good indication that I did it right. As far as the device is concerned, I thought it was a config. problem with the software. I attempted both ports [COM1 and COM2] while using hyperterm but none of the keystrokes were displayed on the panel. I installed LCD driver software and this didn't seem to work either [it figures because Hyperterm didn't work]. I hope this was sufficient. Please respond with your suggestions. Thanks again.
anaknangputa
BTW....The settings on the software matched the physical connections.
Stig
Post by Stig »
Hi.
Just a sugestion, have you checked that your serial cable is good and not the wrong type, i.e. not a null-modem cable?
Stig
get rid of LCDriver and use Alpha Demo supplied by us.. and try it in there.
anaknangputa
STIG.....
I think you're right.... I used an old DB9 cable I found layin' around. Can I get this serial cable from the local PC shop? What spec. should I be lookin' for??
Standard serial cable... NOT null...
anaknangputa
The cable I currently have is a Belkin DB9. Is this the same as what you suggested??
Shrug... it has to be straight through pin out.
