LVK204-25 PCB V.3.0 -- messed up jumper move, any hope?
phildogginit
Post by phildogginit »
I attempted to move the jumpers from the rs232 square to the I2C square but made a mess of it, being inexperienced and having shaky hands.
There currently are no jumpers in any of the 5 squares.
What can I do to fix it? I want to run in I2C mode.
thanks
Phil M
Hi Phil,
The protocol resistors have a value of 0ohms; if you have removed them and all pads are intact you are in good shape. To bridge the connections for I2C, you can use a blob of solder on each of the two connections required, which should be easier than playing with those resistors.
