DE-LM106, issues
bouvett
DE-LM106, issues
Post by bouvett »
HI GUYS,
i have just started my first graphical lcd project, which will involves the interfacing of a GLCD with a microcontroller. the lcd i bought is the de-lm106 whose datasheet is http://www.mmtelec.com/download/CA12864 ... Module.pdf
now i cannot find info about how to configure the lcd such as initial settings or that sort of info. i have found one datasheet about this lcd, i setup the code of the microcontroller but when i tried it out nothing worked, all i did is reset the graphical lcd, switched on the display and started inputting data.
the code is attached just in case( it is in assembly and for PIC micros)
any help will be greatly appreciated.
thanks guys
Hello and welcome,
these forums are for Matrix Orbital products only... and I would recommend our intelligent graphic LCD for your project, it will be significantly easier and faster.
