loois
Post
by loois »
I've just order my nk204-v and i want to mount it externally, can i use the 5v from a usb cable or do i need to take 12v from a molex
Any ideas on other ways
- OMNIPRESENT
Post
by Henry »
if you:
1. by pass the voltage regulator
2. put +5V into the DB-9 connector
you will be able to power the LCD with +5V
loois
Post
by loois »
Cheers for the quick response,
1) do i just bridge the voltage regulator with wire.
Do i get 5v from inside the case (molex)
- OMNIPRESENT
Post
by Henry »
if you are using power from the computer, why not just use 12V then? and yes, you can just bridge the voltage regulator.
