GLK12232-25, i just Wiped module file system!!
M0rt
Post by M0rt »
Hi
i have a GLK12232-25, i just Wiped module file system in mogd.exe!!
wot does that do and how can i reverse it as i cant seem 2 upload anything 2 it
turn the display off, and then try again... if that doesn't work, open hyper terminal and see if you cen get keypresses to display there. Or try using Version program to see if you can get type or version from the display.
_________________
<font size=-1>[ This Message was edited by: Henry on 2002-03-26 22:25 ]</font>
M0rt
Post by M0rt »
ok turned it off
i cant seem 2 get it working with lcd smartie and it keeps messing up, the screen fandomly messing up etc etc
any ideas
M0rt
Post by M0rt »
i'm having a lot of hassle with my lcd and its not doing wot i want it 2 =[
also was under the impression that it was blue on white, instead this lcd is black on green, WTF!!
some help please?
1. LCD Smartie and Graphic LCD do not mix.
LCD Center 2.0
LCDC
LCD Stats
2. Ther are 2 version of the GLK12232, the GLK12232-25 and GLK12232-25-WBL... double check what you actualy bought and if you bought it from us, contact adam (alintott@matrixorbital.com) and talk to him...
M0rt
Post by M0rt »
i think the 1 i have recieved is the 1 without the WBL bit, but i ordered the blue 1 so that was the 1 i was meant 2 get
i'll email him later
thanks 4 ure help
