I wonder if anyone has had a similar problem and knows of a resolution. I have a LK204-25 with the extended temperature and supply voltage options.
At the moment when it is powered up without shorting the Manual Overide pins, the controller boots up with an unknown baud rate and nothing can talk to it. If I hold down buttons on the keypad that provide me with the manual over ride, the controller behaves as expected and I can talk to it.
I have tried reprogramming it from the uproject software after booting up with manual override. I have tried turning on remember and programing and using scripts but nothing works. Things like the user specified startup screen get saved and work but the baud rate always goes nuts.
The LCD is talking to a National Instruments controller and this did have some problems and I think at one point it threw a heap of stuff at the LCD and I am not sure if this corrupted the buffers. I definitely had the startup screen completely garbled after one such incident.
The behaviour I am describing now however is not due to the National Instruments controller or my software but is reproducible with uproject and a PC.
To recap, when the manual over ride button is held down, the controller starts up and communicates ok but if this is not done, it comes up with an unknown baud rate. The effect of this is that nothing inteligible gets read on the screen and the key presses do not get sent back correctly.
Please help!!
Thanks in advance.
Peter
