i am using GLK24064-16-1U type display. I have downloaded the MOGO Sharp tool to test it. But with this tool i am not able to test my Keypads. Wen i try to use the uProject to test it i am getting only 0xFF amd 0xFE.Can any one provide guidelines to check my keypad and tool to test it. i am communicating the diplay by mini USB.
Thanks and Reagards:
arun.m
Need tools to test keypad for GLK series
Anbudan Arun.M
Thanks for your post.
With uProject, try to connect to the display. Please note that you will have to connect to a virtual comport, since you have a -USB display.
Make sure that you have the flow control off to start, to be able to test the transmitted data (from key presses). Also, make sure that you have Auto Transmit On for key presses.
Let me know if this helps.
