Current requirements for 20x4 VFDs
paramotor
Post by paramotor »
I had 16x2 VFD display for my project that worked fine. I needed more space to display stuff so I replaced it with 20x4 VFD display. The way this new display behaves is it comes on displaying my info for about a second, then comes off. It is connected to MCU. MCU continues to work, but VFD doesnt come on anymore. If I reset the power, it does come on for a second, then immediately off. I suspect it draws more current. Does it sound like it is an issue of insufficient current for VFD? How much current does 20x4 actually draw? I have 1A 5V regulator.
The 4x20 VFD can have a 550mA in rush power requirement. The current draw after is dependent on how many pixels are ON, so I would recommend a 350mA power supply or so... But Raquel will double check on that for you.
Hello paramotor,
The power supply current for when all of the dots in the screen is lit is 350mA max (275mA typical). The in-rush current is anticipated to be twice as the normal current. So a power supply that can handle 700mA should be sufficient.
paramotor
Post by paramotor »
thanks guys. i found out what the problem was. it was NOT a power supply. 20x4 parallel VFD (from M-O) is not exactly Toshiba compatible and would malfunction on some commands that 16x2 VFD (or any truly compatible LCD) would support fine.
Glad to hear that you've figured it out.
