2 Mx620 units in one system?
creepyarcade
Post by creepyarcade »
It is possible to install and seamlessly run 2 mx620 units in one system and have them be controlled independently of each other with each unit displaying different groups of data?
Yes it's possible, you could run 100+ displays on a single system. When you plug in both displays each will have its own COM Port, then all you have to do is launch 2 copies of LCDC and set each to the two COM Ports and you should be good to go.
