Moderators: Henry , Mods
Delta
Posts: 20 Joined: Wed Jan 30, 2002 4:00 pm
Post
by Delta » Mon Mar 04, 2002 11:23 am
There doesnt seem to be any GPOs on my GLK 12232-25-WBL, G1 and G2 are there..but no pins are soldered to them...
Posts: 3014 Joined: Tue Aug 14, 2001 6:00 pm
Post
by Henry » Mon Mar 04, 2002 11:35 am
That's right... the pins are not soldered on.
Delta
Post
by Delta » Tue Mar 05, 2002 4:03 pm
so i have to void the warranty to use the GPO's?
Post
by Henry » Tue Mar 05, 2002 4:10 pm
Yes and no... if you solder the GPOs and destroy the LCD in the process, yes it's void, but if you solder them on and something else fails on the LCD, like the RS232 chip or mem ship, it will be covered.
Delta
Post
by Delta » Tue Mar 05, 2002 6:21 pm
sounds fun, looks like i'll be doing a spot of soldering later
Delta
Post
by Delta » Tue Mar 05, 2002 6:23 pm
what do the other pins do btw that arent soldered, rst and cont..it says on the site "do not use" but what are they actaully for?
Post
by Henry » Tue Mar 05, 2002 6:24 pm
DO NOT USE...
Nothing usefull for 99.9% of the people...
Delta
Post
by Delta » Wed Mar 06, 2002 5:17 am
what about SCL and SDA?.. and that other spare conenctor bloke at the top?
(ur speaking to someone who before USB was on everyboard you bought, soldered the pins onto his VX mobo and made a header to 'see what it did'
specialk
Posts: 75 Joined: Mon Jan 14, 2002 4:00 pm
Post
by specialk » Wed Mar 06, 2002 6:55 am
From the LCD datasheets:
SCL-I2C clock
SDA-I2C data
The rst and cont are undocumented (just says "do not use") and I'd love to know what they are for too... Henry, what are you hiding?
-special [k]
Aniso
-=Beloved by all=-
Posts: 286 Joined: Tue Aug 14, 2001 6:00 pm
Post
by Aniso » Thu Mar 07, 2002 10:27 pm
rst is /reset (reset for the processor anyway)- active low.
cnt is the contrast control voltage. The actual voltage that is being fed into the LCD drive circuit.
... or that is what they were before other engineers messed with the board layout without permission...
