i have recently added a mx 600 pled screen to my pc using the internal usb and although i fitted and installed correctly im having a problem when i activate the screen in lcdc, ihave the latest drivers and my bios is up to date but when iset the example file running [all infomation is correct and the screen works fine] my keyboard,an ideazon z board becomes corrupted or stops working and occasionaly my mouse stops as well which is plugged into the usb port on the keyboard im running windows xp on an msiskt 754 k8n neo board
any advise would be much appreciated
thanks
noob needs help
Hi Braibo,
Please try removing and reinstalling the drivers and the registry entries. The registry entries can be found at http://www.lcdforums.com/forums/viewtopic.php?t=1016
Try this and let me know how it works.
thanks tom ,i tried reinstallimg with no luck
but i thought seeing as i carfully followed every instruction and iv not seen anyone post a similar problem it could be hardware or bad wireing on my part .
so i tried installing it with the external usb cable and lo and behold its now working fine.
seing as i double checked all my wireing i think i may have damaged it with my heatgun when i was braiding it doh
anyway thanks again for your help
