GLK12232-25-SM RS232 Convert
I just bought the GLK12232-25-SM, but didn't by the serial cable convert it to the 4 pin. So my question is which pins on the lcd, connect to which pins on the seral port of the computer. I found out on the computer, pin 2 is RX, pin 3 is TX, and Pin 5 is signal ground. (Please correct me if im wrong). So basicly which pins connect to the lcd
Thank you for contacting the forums.
The table below shows you how the display should be connected to your pc.
Pin Number | Direction | Description | LCD Host
2 | Data from LCD | Data out (LCD) | Tx Rx
3 | Data to LCD | Data in (LCD) | Rx Tx
5 | - | Ground | gnd gnd
