VK204-24-USB stopped working tonight
Tonight my Display quit on me. I have tested it on two machines and all what happens is Windows XP detects it and installs the driver but LCDC or any other program cant detect it.
Is there a way to reset the display? The screen is just dark. I don't even get the Matrix Orbital Logo when powered up.
Well... I see what happend. When I was screwing a fan back in I pinched two of the 3 fan wires between the fan and the case which broke through the insolation causing a short. Looks like I killed it.
I don't think this would be covered on warrenty. Would it just be cheeper and quicker to buy another?
Yep.. tried even on an extra powersupply that I use for testing fans and other equipment. (Modded so I dont have to have it conneted to a MOBO)
The screen stays dark. This happend earlier over the weekend (prior to the fan insodent) when I was messing with Girder's LCD driver plugin. LCDC stopped working and for a little bit I couldn't get the display to work again till I powered down the whole system (standard windows reboot left the screen blank) and unplugged the power supply. Once I plugged everything back in and booted up I finally got the MO logo and LCDC started working again.
Shouldn't I get the logo even when the display isn't plugged into the USB of a machine? If so... I don't.
In the mean time I purchased another one for a replacement. If I can get this working though it will be great. I will have one for the HTPC and the other for the gaming machine. I really liked having it on my gaming machine when I was testing it with the new TeamSpeak Pluggin for LCDC.
Please email me at tlam@matrixorbital.ca and we can discuss RMA options.
Have you tested it out with the LCD tester? If you don't have it, you can download it at http://www.matrixorbital.com/pages/downloads.asp.
I haven't gotten your email yet. When you email me, can you provide a high resolution picture of the back of your display for me?
My email again is tlam@matrixorbital.ca
I cant see anything or smell anything that would suggest dammaged curcuits. I think the firmware might of corrupted if it is possible. It installs fine and XP sees it in the device manager but the other programs don't recive the ID when they try to connect to it. Is there anyway I can TS into the device to test it some more?
Do you have display tuner? It comes with the CD thats packaged with the display. You can also test it with LCD tester. The link for downloading it is below.
Have you tried resetting it?
## # Mat # ##
http://www.lcdc.cc
Matthew@DPS.uk.com
DPS Ltd. (Not MO!)
http://www.lcdc.cc
Matthew@DPS.uk.com
DPS Ltd. (Not MO!)
