Please help, corrupt display (MX224)
No matter what I do, the display shows gibberish characters. I have tried to install the drivers again, updated to the latest version of LCDC, etc. No luck.
This display worked great for almost a year. Now the display is very dim and displays weird characters. When I unplug it from the USB connection and plug it back in, I don't even get the default 'Matrix Orbital' display text, just junk. You see each 'cell' of the display light up for a fraction of a second and then it dims and shows junk.
Any help or ideas about what I can do would be great.
The following shows in my device manager:
Ports (COM & LPT): Matrix Orbital MX2xx USB Driver (COM3)
Universal Serial Bus controllers: Matrix Orbital MX2xx USB Driver
Driver Info
Date: 2/1/2002
Version: 1.0.2101.0
Driver Info
Date: 2/1/2002
Version: 1.0.2101.0
Can you try the following instructions?
1)Unpower your display
2)Place a jumper on pin 6 and 7
3)Power up your display again
4)The Baud will be set at a default 19200
Refer to the link, which is the manual, below. The instructions are on page 7 of the pdf file.
http://www.matrixorbital.com/manuals/LK ... USB_01.pdf
looking for an extra jumper ...be right with you...
Tom wrote:Can you try the following instructions?
Ok...I have set a jumper on pin 6 and 7 and things look the same so far.
Synapse wrote:looking for an extra jumper ...be right with you...![]()
FYI...I can enter characters and they show on the screen through HyperTerminal.
