Is my GLK12232-25-SM Working Right?
dug1967
Post by dug1967 »
I have had this display setup and playing with for about two weeks now. But I am really not able to get it to function right.
The modg.exe software kind of works, but like if I upload the Casus graphic image in the software, it ony displays the top half.....
If I draw a free hand display in the "drawing tool" and preview it, it comes up but only the top half again and it also loses a lot of lines and portions of what should be there.
Also the LCD tester program doesn't seem to do anything. I open it and it comes up with a small little box with two scroll windows in it. The box is so small I can't see anything and I can't expand it..... If I scroll over I see a oval click box with "Text Graphics" in it, but it does nothing.
All I want to do it set a string of graphics displays to cycle through on the display, is there not a program (with help files to explain how to do that) to do that???
Any ideas and help will be most appreciated. Thanks in advancee
When using mogd.exe make sure in your settings tab you have the display size set to 122x32. Mogd.exe will load the appropriate bitmaps in the corresponding reference number. You can then draw any image you like from were it's referenced! :D
