I have been trying to find some combination in LCDC to get a result like:
"when NetDwn>40KBs, then strobe GP5"
I can set up text to show the NetDwn number and I can tell LCDC that when that number is diplayed then GOTO Event XX. That is not the same as the logic above.
But I see no way to have LCDC analyze the logic of >40KBs.
I think LCDC is well integrated with MBM 5 to adjust fan speeds as Temps increase, but the System Plugin doesn't seem to give that type of Robust adjustment? The logic analysis is similar:
"when Temp>60C, then increase fan 10%" but the plugin for System events doesn't seem to have that option.
Am I looking in the wrong place, or is this just a feature set that no one else has a need for?
conditional event triggers...still can't figure it out.
There is no event for netdown, never come up before. However the next release of LCDC has a new GPO sequencer built in, and it would be possible using this. There may also be a new generic check coming in to lcdc as well
## # Mat # ##
http://www.lcdc.cc
Matthew@DPS.uk.com
DPS Ltd. (Not MO!)
http://www.lcdc.cc
Matthew@DPS.uk.com
DPS Ltd. (Not MO!)
thanks, I saw some of that mentioned on the LCDC forums site, and I am hopeful that I will be able to trigger things with more precision than current plugins.
I would like to do things like trigger stuff on MemBandwdth>XX, and NetupKBs>XX and such. That would be really nice to have a general GPO logic system as long as you can find the input data.
