LK204-25-PC GPO
ultraspider
Post by ultraspider »
On the LK204-25-PC there is 26 pin for the GPOs but only pin 1 to 16 are the 12 V GPO. what can we do with the 10 other pins ???
What is an inductive load???
Am I obliged to "clamp" (i don't know what it mean) each GPO to switch fans, neon light, ...?
thanks for your help.
linear
evil Dr. linear
evil Dr. linear
Post by linear »
If your load is inductive (like a fan, relay, or solenoid) you want to use a diode reverse biased to 'clamp' the output. It flattens the peak of a the transient voltage that can occur when an inductive load is switched on. It protects the rest of your circuits from being damaged by the transient.
Have a look at this app note for a nice explanation: http://www.littelfuse.com/PDFs/Resources/Diodes.pdf
