had a glk12232 25sm now for 4 days some times works and then do's
will work in lcdc for about ten minutes then lock
then if i run mogd an try and print to screen just get rubbish
only seem to be using 2 thirds of the screen
if i try to load a font get error message
so i have to take out lcd and do a reset it ok for 10 minutes
then guess what it dos it again i am get a bit peed off
help do i have a problem
Hello...
The GLK12232-25-SM was designed to be implemented in a variety of embedded systems. Although useful for personal use, the full range of abilities is somewhat hampered. For the start-up screen you can email me at myero@matrixorbital.com and I'll set you up with it. What type of software are you using to display bitmaps...? Also you can check out this link for some additional ideas for programming: http://www.lennard.net.nz/lennardelectr ... d.html#adc
