Website page errors
WildRice
Website page errors
Post by WildRice »
Love the site. Love the products, but it would be really nice if you ran your web pages through:
http://validator.w3.org/check?uri=http: ... bital.com/
http://validator.w3.org/check?uri=http% ... +Europe%29
The errors are pretty bad, slow the site down, and in some cases render incorrectly on some browsers. Thanks. -Chuck-
This page is not Valid HTML 4.01 Transitional!
Below are the results of attempting to parse this document with an SGML parser.
Line 17, column 29: required attribute "TYPE" not specified (explain...).
<SCRIPT language="JavaScript">
Line 27, column 38: required attribute "TYPE" not specified (explain...).
</SCRIPT><script language="JavaScript">
Line 57, column 31: required attribute "TYPE" not specified (explain...).
Line 65, column 52: there is no attribute "TOPMARGIN" (explain...).
...><body background="bg.jpg" topmargin=0 leftmargin=0 marginwidth=0 marginheigh
Line 65, column 65: there is no attribute "LEFTMARGIN" (explain...).
...ound="bg.jpg" topmargin=0 leftmargin=0 marginwidth=0 marginheight=0 text="#cc
Line 65, column 79: there is no attribute "MARGINWIDTH" (explain...).
...topmargin=0 leftmargin=0 marginwidth=0 marginheight=0 text="#cccccc" link="#0
Line 65, column 94: there is no attribute "MARGINHEIGHT" (explain...).
...tmargin=0 marginwidth=0 marginheight=0 text="#cccccc" link="#00cc00" vlink="#
Line 66, column 29: required attribute "TYPE" not specified (explain...).
Line 71, column 29: required attribute "TYPE" not specified (explain...).
Line 76, column 29: required attribute "TYPE" not specified (explain...).
Line 81, column 29: required attribute "TYPE" not specified (explain...).
Line 86, column 29: required attribute "TYPE" not specified (explain...).
Line 91, column 29: required attribute "TYPE" not specified (explain...).
Line 96, column 29: required attribute "TYPE" not specified (explain...).
Line 106, column 125: required attribute "ALT" not specified (explain...).
..." width="510" height="147" border="0"></td><td WIDTH=35%><br>&nbsp;<br></td><
Line 106, column 143: an attribute value must be a literal unless it contains only name characters (explain...).
...ht="147" border="0"></td><td WIDTH=35%><br>&nbsp;<br></td><td valign=top>
Line 107, column 217: required attribute "ALT" not specified (explain...).
...h=127 height=50 border=0 name="homeD"></a><br clear=all><a href="help.htm" on
Line 107, column 452: required attribute "ALT" not specified (explain...).
...h=127 height=97 border=0 name="helpD"></a></td>
Line 108, column 224: required attribute "ALT" not specified (explain...).
...dth=127 height=50 border=0 name="smD"></a><br clear=all>
Line 111, column 219: required attribute "ALT" not specified (explain...).
...9" height="97" border="0" name="manD"></a></td>
Line 113, column 252: required attribute "ALT" not specified (explain...).
...88 height=50 border=0 name="contactD"></a><br clear=all><a href="privacy.htm"
Line 113, column 504: required attribute "ALT" not specified (explain...).
...88 height=49 border=0 name="privacyD"></a></td>
Line 117, column 55: there is no attribute "HEIGHT" (explain...).
<table border="0" width="65%" cellspacing="0" height="743">
Line 121, column 27: document type does not allow element "P" here; missing one of "APPLET", "OBJECT", "MAP", "IFRAME", "BUTTON" start-tag
<p align="center"><FONT FACE="Arial, Helvetica, Sans Serif" SIZE="2"><
Line 134, column 141: required attribute "ALT" not specified (explain...).
...g" width="250" height="78" border="0"></a></p>
Line 145, column 127: required attribute "ALT" not specified (explain...).
...g" width="200" height="63" border="0"></a></div>
Line 148, column 125: required attribute "ALT" not specified (explain...).
..." width="200" height="123" border="0"></a></div>
Line 151, column 123: required attribute "ALT" not specified (explain...).
...g" width="200" height="62" border="0"></a></div>
Line 185, column 19: end tag for element "P" which is not open (explain...).
</p>
Line 191, column 17: end tag for element "P" which is not open (explain...).
</p>
Line 265, column 12: document type does not allow element "P" here; missing one of "APPLET", "OBJECT", "MAP", "IFRAME", "BUTTON" start-tag
<p>&nbsp;
Line 266, column 12: document type does not allow element "P" here; missing one of "APPLET", "OBJECT", "MAP", "IFRAME", "BUTTON" start-tag
<p>&nbsp;
Line 267, column 12: document type does not allow element "P" here; missing one of "APPLET", "OBJECT", "MAP", "IFRAME", "BUTTON" start-tag
<p><font size="2" face="Arial, Helvetica, sans-serif">Browse our <b><a
Line 269, column 12: document type does not allow element "P" here; missing one of "APPLET", "OBJECT", "MAP", "IFRAME", "BUTTON" start-tag
<p>&nbsp;
Source Listing
We have stoped working/updating the current website as the new one should be released on July 1st! It will be much much much (trust me, much) better... Thankyou for you input, it's nice to sso our customers care :)
