could someone test this code? vb6 program for 20X4 LCDs
Ghoast
Post by Ghoast »
I haven't got a display to test the program with so could someone please test it for me?
download from:
http://w1.262.telia.com/~u26209407/lcdstats.zip
you'll need vb6 runtime to run the program
source code included in zip file.
screenshot:
http://w1.262.telia.com/~u26209407/Untitled-1.jpg
edit: i forgot to say that you need Motherboard Monitor version 5.1 or above to run it.
<font size=-1>[ This Message was edited by: Ghoast on 2001-12-03 08:51 ]</font>
Well, I tried it and I keep getting a error that I'm using MBM5 pre 5.1 even though I'm using 5.1.0.2. I re-installed it, and reboted and I still get the same problem.
Ghoast
Post by Ghoast »
Did you have MBM running when you tested?
Ghoast
Post by Ghoast »
installer for the program at:
http://w1.262.telia.com/~u26209407/LCDstats.zip
VB6 source code at:
http://w1.262.telia.com/~u26209407/LCDs ... cecode.zip
<font size=-1>[ This Message was edited by: ghoast on 2002-01-03 06:19 ]</font>
Shak
Post by Shak »
hmm, those links are dead
work fine for me...
Shak
Post by Shak »
even the source code one?
Got me on that one :grin:
Shak
Post by Shak »
hmm, I am writing a SETI LCD program, trying extract the progress is tricky
Shak
Ghoast
Post by Ghoast »
I updated the link.
Shak
Post by Shak »
what coed was it to check the email?
I cant find it :sad:
Shak
Ghoast
Post by Ghoast »
The code is in a sub called CheckEmail and in the winsock data arrival event. It's heavily commented. Tell me if you need any help with it.
The source code is for the program called LCDstats which has it's own thread. Have you tested it?
Shak
Post by Shak »
would do if I had an LCD...
where is LCD which you can use to send data to LCD?
Shak
