LK204-PC + LCDriver
tigermain
Post by tigermain »
OK peeps, I know there are a fair few of you out there, and wondered if you are all having the same issue as me !
When I use LCDriver and the winamp plugin the whole output is raised 1 row so I miss the top row and have a blank bottom one.
Haven't had time to work out if this is a problem with LCDriver itself or just the winamp vis.
Anyone care to share in the problem and maybe shed some light so we can try and get this problem sorted !!
_________________
In CyberSpace no-one can here you moddin'
http://www.moddin.net
tigermain@moddin.net
ICQ 2481719
<font size=-1>[ This Message was edited by: tigermain on 2001-12-03 07:15 ]</font>
ctimmer
Post by ctimmer »
If text cursor positioning is used the software may be assuming the first row is zero. I believe it is actually 1 (the manual is not very clear on this). This error could generate the results you are seeing.
