Mount LK202-24-USB in a 3.5" Bay in a mini cube pc(in)
NIVO
Post by NIVO »
Hello guys. Just wondering if the usb model will be able to mount in a 3.5 drive bay?(at least the lcd itself, not the whole piece of hardware). I just got my FIC IC-VG61 ICE CUBE and it only has a panel for 5.25" which is used for a cdrw/dvd combo drive and one 3.5" panel which wont be used, except for the lcd, I HOPE! hehe Anyhoo, since the case is silver(aluminum appearance) I would like to know if it will fit the 3.5" bay and if so do you make silver finish inserts? Also it is no problem to do mods to the front of the pc as I have access to aluminum, sheet metal, laser cut tools, etc. Was just hoping it would be easier to install. Please shed some feedback on ideas. Thanks. I only want the best in my Cube, and well, MatrixOrbital IS the Best!
calvin166
Post by calvin166 »
umm 3.5 thats pretty small. the screen would just barely fit. and even so mo doesnt sell 3.5 inserts only cd size inserts :)
-Calvin166
"... and then..."
NIVO
Post by NIVO »
ok thanks for the reply, i will custom make my own aluminum bezel then.
SiCo
Post by SiCo »
The screen itself will jusfit (visible area) but you will need to sort the case to house the circuit boards etc as they are wider than 3 1/2", could be done though You won't need a very big bezel though!
