GPO Default values...
thedogcow
Post by thedogcow »
I was wondering, im looking at buying the usb lcd that u sell but am wondering about the gpo's... do they default to on when the lcd powers up, and if not is there a way to change it so they dO? Thanx
They should be all off. Some of the new units (LK/VK202-24-USB, LK/VK202-25, LK/VK204-25) will get this option over time, but no unit can do this at the moment and no ETA can be given either.
Cheese
Bit-Tech.net
Bit-Tech.net
Post by Cheese »
You can of course use a little bit of electronics to invert the default GPO state, but with high power GPO's it's a little bit of a pain (using solid state at least, clearly you could use relays too).
Rob.
JeffPh
Post by JeffPh »
i think u can set it to on using lcdc. in the configuration of GPO there is a on option at start and on at exit all 6 gpo's. Am using a 202 usb MX 222.
Cheese
Bit-Tech.net
Bit-Tech.net
Post by Cheese »
JeffPh wrote:i think u can set it to on using lcdc. in the configuration of GPO there is a on option at start and on at exit all 6 gpo's. Am using a 202 usb MX 222.
Yes of course you can, but that won't turn them on when you switch your computer on. THe issue is if you are using the GPO's to control system vital fans, you don't want them to be all off when you start your computer :)
Rob.
JeffPh
Post by JeffPh »
hehe ur right :)
but it will just take about 10 secs at most upon boot up when u load lcdc to start with windows :) just a thot not the cpu fan tho....
