5v or 12v ? i am a little confused with my LK204-25-PC !
Fierce_Brake
Post by Fierce_Brake »
Hi there!
I just bought a LK204-25-PC LCD but i am cofused about the voltage!. Correct me if i am wrong:
This unit accepts 5v or 12v.
-I can feed the unit with 12v from the the same connectors wich feeds up
the cdrom and hd ??, if so, i have to get a special cable ?
-I can feed the unit with 5v using a normal floppy drive connector ?
Thank you for your help guys !
Fierce_Brake
it uses an unmoddified power cable, read the little sticker that was over the header, also, check the manual if in doubt.
