MX212 WINDOWS XP PROBLEM
Narayan
Post by Narayan »
all the drivers are from the fourm
Muzzlehatch
DLL problems with LCDC
Post by Muzzlehatch »
Naryan, I had your problem too and I fixed it by installing the latest LCDC (1.05.26) This version just came out and if you don't have it try getting it from http://www.lcdc.cc/downloads.htm. All my weird .dll problems went away when I installed this upgrade.
HTH!
Anarchi5t
Try This
Post by Anarchi5t »
Narayan,
Did you get your problem resolved...?
DrBob147
Post by DrBob147 »
All you guys having problems installing the drivers on WinXP...
You must totally remove the old drivers before you install the new V1.1...the only way that it worked for me was to go to "control panel"...click on "add/remove programs"...then search for MO Drivers and click Remove. It seems that windows does not like to totally remove stuff any other way. NOTE: when doing this, make sure that your display is disconnected...after removing the old drivers, plug the USD cable back in and when it says "new hardware found", have the Hardware Wizard point to the new drivers (V1.1) that you downloaded from the link above. This has worked perfectly for me and a few others that I know...Good luck!
. DrBob147 .
"We make a living by what we get,
we make a life by what we give."
Thanks for the post DrBob...!! :D :D
