How to fix the USB Drivers under Win XP
Anarchi5t
Post by Anarchi5t »
Ok ive reposted this to help anyone else out having this problem. If possible guys could we make this a sticky post to help everyone <:)
Ok
The problem lies with the drivers on the CD apparently the wrong drivers were placed on the CD or somthin. If you install the device under this Windows will copy them to your driver folder and use them for the device constantly.
You need to download the V10 drivers and then extract them to a folder on your computer.
http://www.matrixorbital.com/download/U ... er_V10.zip
(hope the guys wont mind me placing a link here )
Now you need to make sure these files are used otherwise Windows will use the CD drivers which is why re-installing windows works because it removes the CD drivers from the folder.
Uninstall both the Display and USB Serial Port from the device manager and then search for new hardware when the Display is located select choose the driver manually and then select to choose the driver specifically yourself.
Now make sure you go to the folder with the V10 drivers in and select the driver needed windows will now use the new V10 drivers and repeat this for the USB Serial Port. Both should now be installed sucessfully and ready to use. :P
I have updated the drivers today, see sticky at the top. I hope this fixes everything :)
