Join the dots!
zander
Join the dots!
Post by zander »
Ok, I'm being pretty slow here I think!
Created a custom keypad with a selection of switches, just trying to wire them up but want to make sure I do it right!
There is a set of 4 in close proximity and another 2. Just going to take another go myself but any help would be appreciated!
Brillig
Post by Brillig »
Did you get this figured out? I could help if you have not.
zander
Post by zander »
At work at the mo so can't upload the diagram of how I think i'll try it.
Basicly wired contact 1 of each switch in the four cluster together to a row then contact 2 to each column. Then I did the same with the second cluster of two but the other way round.
If I get a chance i'll try it this evening, but if you feel like playing in paint i'd appreciate confirmation that what i'm doing is right!
Thanks for the help!
zmoreira
Post by zmoreira »
Brillig wrote:Did you get this figured out? I could help if you have not.
Brillig: I am wondering how to do the same thing, can you help? Just a quick hot-to to get me started...
zander
Post by zander »
Mine worked the way I did the diagram, just as long as you connect each switch to one row and one column.
