Custon Keypad for HTPC
ftjandra , I love the keypad you made, do you have more pictures you could show us of that? how how you did it?!
Check it out
http://www.mindspring.com/~ftjandra2/my_htpc/index.html
ftjandra
Post by ftjandra »
Yes, the next time it's apart, I will post more pics. Should be in a couple of days.
--Ferdi
can't wait!!!
ftjandra
Here are the pics
Post by ftjandra »
Here are the pics as promised.
Here is a picture of the back of the facia with the ribbon cable.
If you look closely at the ribbon cable you can see that the first lead isn't even used, hence no cable soldered on.
Here are the connections to the actual VFD. The way the 5-way button was set-up was that it had 6 leads, with one being common. When a button was pressed, it would connect the circuit with the common lead. The cable all the way on the right (pin6) is the common one. So, the way it's set up, the VFD outputs the letters A-E when a button is pressed.
linear
evil Dr. linear
evil Dr. linear
Post by linear »
clean! Impressive work for sure.
VERY WELL DONE!!!
