help
abyss
help
Post by abyss »
hello everyone
i just bought a lcd blk202a -r
mbm5 the newest one works fine and display to me everything i need but lcdc in the plug in configuration does not allow me to configurate and when i hit refresh list it uncheck the mm5 option
any ideas?
Do you have MBM5 installed?
abyss
Post by abyss »
Henry wrote:Do you have MBM5 installed?
yes
abyss
Post by abyss »
yes
help
still have the same problem
any suggestions?
thanks in advance for your help
Mat-Moo
Post by Mat-Moo »
Ok, you've gone into the LCDC configuration, then the plguins page and selected MM5. You then hit save? then refresh and it's gone again?
abyss
Post by abyss »
mat-d-rat wrote:Ok, you've gone into the LCDC configuration, then the plguins page and selected MM5. You then hit save? then refresh and it's gone again?
it doesnt let me configure it in lcdc and it display no infos
Mat-Moo
Post by Mat-Moo »
Yes but have you put a tick in the line next to it to get LCDC to load in that plugin? If you have then from the screen builder you can click on the end of a line to bring up the text definition screen and see all the MM5 (MBM) variables avialble to you.
abyss
Post by abyss »
mat-d-rat wrote:Yes but have you put a tick in the line next to it to get LCDC to load in that plugin? If you have then from the screen builder you can click on the end of a line to bring up the text definition screen and see all the MM5 (MBM) variables avialble to you.
yes i did it and yes in the screen builder i clik at the end of the line and mbm appears but when i click on it to select temp fan etc it doesnt display nothing
all it says is ="N.A"
it doesnt display the temperatures etc when everything works perfectly in the dashboard of mbm
Mat-Moo
Post by Mat-Moo »
What version of MBM?
abyss
Post by abyss »
mat-d-rat wrote:What version of MBM?
version5.08
Mat-Moo
Post by Mat-Moo »
Try upgrading to the later 5.2.0.0 there was some changes which I though I had working both ways, but possibly not.
